Hello.
a '02 Q45 i recently purchased has issues where the FOB does not lock/unlock the doors or open the trunk. Power lock button on driver-side door does not work either.
Power seat positioning does not work either, and i thought that to be managed by the BCM because of the driver "preference memory" that you can set.
When i had it scanned at O'reilly's, their OBD scanner returned a code along the lines of an "immu-key"? but my FOB does start the car from the ignition.
Could these symptons be from a bad BCM?
