homeslicej2 »
https://forums.nicoclub.com/homeslicej2-u54419.html
Wed Jan 17, 2007 8:08 am
First off, based on your drawing I still can't really tell how you've wired your subs. Also, are they SVC or DVC (single or dual voice-coil)? That's is important to know. I assume they are SVC. In that case it looks like they are parallel this would give you a 2-ohm load. Most 2-channel amps are not 2-ohm stable in a bridged configuration. If you want a 1-ohm load capable amp, they usually more expensive. FYI running an amp at 1-ohm, even if it's capable of it, results in several things, some of the most important ones are more heat and more distortion. Both translate into shorter amp and sub life and greater potential for hearing damage. Many brands make 1-ohm stable amps. Some to consider might include Hifonics or Memphis, but there many others. Google it. Googling works to answer your sub wiring question as well. There are several good diagrams and car audio learning centers on the web. Here is a link to Crutchfield's sub wiring diagrams. http://www.crutchfieldadvisor.....html
A few last questions. You said you replaced the power and ground wires. What size were they, what size are they now, did you remove all paint and go to bare metal for the ground and paint over it to keep the the metal from rusting, and what is the fuse rating of your amp? This and the amp's RMS (not peak, which is most likely what is written on the top of your amp) wattage output along with length of power wire will help to determine the appropriate size power wire needed.
Last thing. Most manufacturers do recommend parallel over series. Not entirely sure why (it deals with the electrical mechanics & properties of the sub but I don't know the nitty-gritty of it), but they do. Hope all this helps.
