blacklist74 wrote:Take the positive cable off the battery while the car is running.
That was good advice, back in 1950...
On modern vehicles, it's a great way to turn one electrical problem into several dozen or so -
The battery serves as a voltage stabilizer and filter. When you disconnect it, your voltage regulator doesn't have a stable voltage to measure - instead, it sees whatever voltage the alternator happens to be producing at that particular instant. Instead of reacting to a voltage that gradually changes over several minutes, it suddenly has to react to voltages that are changing almost instantaneously. Result: Huge voltage spikes and sags.
Worse yet, since your alternator produces pulsating DC, its output swings from zero to 20+ volts anywhere from several hundred to several tens of thousands of times a second. Without a battery in the circuit to smooth out these pulsations, every electronic device in your vehicle receives this "raw" DC power.
With literally hundreds of electronic circuits in the average modern car, you're just begging for trouble by exposing them to this garbage.
