jerrythedonkey »
https://forums.nicoclub.com/jerrythedonkey-u168849.html
Mon Oct 25, 2010 1:05 pm
advance/autozone/ect bench tester really isnt that realiable. I have had numerous (used to work at advance many moons ago and they havent changed the bench tester) alts test good on the bench when it comes to voltage but not put enough AMPS out under load when installed on the car and put to work.
If you can, some new advance autos have a hand held unit that will put the charging system under load and work better than the crappy bench unit when its installed. however, i cant imagine finding one used is that hard/nor expensive. why not just grab one and try it? i typically would not recommend throwing parts at ANY problem, but i personally hate charging issues and getting stuck on the side of the road sucks...
i know u said u checked your grounds, but the one on the battery tray kinda blows...why not replace/redo that one while you're doing charging system maintenance
