yes i have probably put to much thought, just using my down time to think about it, i got the motor all torn apart and putting new crap in it so im trying not to dangle it to much hahathis is going s13 and i heard the intake manifold did not clear the hood on the s13, point for this thread to see what i can find out ideas for...240z4u wrote:Your really putting too much thought into this. Stick the motor in the car hanging from a hoist and it becomes clear.
I have done two set of motor mounts. One set lowered the motor so there was very little clearance between the cross member and pan. Fine and dandy, but as Coolwhip said.. I banged my pan on the ground HARD one time. That was enough for me to move the motor up and have the bottom of the pan flush with the cross member. There is also enough room, barely, to sneak the power steering rack out.
I used 2x2 heavy box tubing and cut the contour to match the mounting pad of the KA motor. Welded it up, put a gusset on it and used (I think) rb26dett isolators. IMO use chevy isolators or something super easy to get and cheap.
This left one problem, which isnt a problem... the oil drain for the turbo is a tight squeeze. If I were to do it again, I would cut most of the mounting pad off of the crossmember and build back to the mounts. This would leave less stuff to interfere. Space is at a premium (unless you do top mount).
This was in an S14. Never have had problems with IM fitment.
