backwards ptu?
DinoTroll1
Car: 1993 Nissan 300ZX
I own a 93 300zx na. i had this car for least 5 months and never had a problem with it till recently when the previous owner "fixes" shown their wear and tear.
after the car overheated it gotten a misfire on cyl 3, and after looking at the ptu it looks like the connecters were spliced to the wrong side. computer which is a 6 pin and blue from diagram, has a 7 pin plug and vise versa. would it be fine considering it been running since i had it? Also i took off all the electrical tap to view this and picture it.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
IIRC the ground wire was on the computer side on all the Z PTU's, so the ECU sides always have 7 (6 controls plus ground) and the engine sides have 6 (one output for each coil). Looks normal to me, albeit very patched-up. The PTU certainly couldn't work backwards, it's an N-transistor array. Swapping the bases and collectors probably wouldn't hurt it, but there would be no function at all.
DinoTroll1
Well that good to hear just gotta redo all the sloppy connections and make it pretty again. Thank you
VStar650CL
Technical Expert
:dblthumb:
