Backup switch engaging in 1 thru 6 in addition to R? WTF?
General discussion area for the L32-chassis Altima
calhoward
Car: 2007 Nissan Altima 2.5 Base
2007 Altima 2.5 Base 6-speed M/T
Hi guys, my problem is this:
My reverse lights come on no matter what gear I'm in. NEUTRAL is fine. I've already replaced the switch. Again, reverse lights come on in ANY gear (1-6 + R), except while in neutral. They turn off in neutral.
At this point I just have the switch unplugged, otherwise I'd be driving around with my reverse lights blasting.
Anybody know wtf causes this? Bad ground? Anywhere I should start looking? Thanks
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
That's a screwy one, the M/T circuit is very straightforward. Fuse -> Switch -> Lamps -> Ground. I'd be inclined to say it's a crossed circuit from another system like the tail or brake lamps except that they go off in Neutral or with the switch unplugged. That means the problem can't possibly be south of the switch. So I think it has to be a mechanical problem with the actuator in the transmission. Nothing else fits the symptoms.
calhoward
Update: I had the neutral safety switch plugged into the backup switch and vice versa. Same part, same connector. Whoops!
Return to “4th Generation Altima Sedan (2007-2012)”
