Backup sensor install
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
roadside
Car: Black '09 Rogue SL FWD (Canadian)
Has anyone installed backup sensors on the Versa? My dad feels that he needs them. I installed some on my Rogue thanks to the excellent instructions in this post:zer...npics
Specifically, I need to know the color of the wire that powers the reverse lights on the Versa. Also, is it really necessary to remove the rear combination lamp in order to remove the bumper?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
This is all covered in the service manual which you will definitely need for such a task: http://www.nicoclub.com/FSM/.
roadside
AFAIK, the service manual does not say which color wire powers the reverse lights. I found the following information on http://www.modifiedlife.com/20...gram/:
2008 Nissan Versa:
Car Reverse Lights Wire (+): YellowCar Reverse Lights Wire Location: In Harness in Driver Side Kick Panel
Can anyone confirm this?
Return to “Versa Technical Discussions”
