I've only installed two universal sonars for customers. They were both China-cheap units off eBay, but they both installed and worked without any real problems. One of them had the control unit and display integrated into a single unit, and I'd suggest avoiding those. It made for routing a lot of wires a long way. You're better off with a unit that has separate control and display units, or just an audio alert without a display. Most of the kits don't have sealed control units, so be careful to mount them where they'll stay dry and put di-grease on all the connectors.
The gen1 FX's don't seem to have had factory sonar, so judging by the pics, I'd say the best spot for the sensors would be in the black under-skirt area indicated by the green arrow. The area with the blue arrow would be usable but may have the impact-bumper directly behind it, so there may not be enough clearance for the sensors. The area with the red arrow is unsuitable, notice it's angled downward and will probably cause ground clutter in the sonar returns. Like any accessory installation, inspect and measure twice (or more) and then cut once. You won't like replacing or repairing a mis-drilled bumper skirt.
- 04 FX35 Sonar.png (179.21 KiB) Viewed 1696 times
