Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Sat Jan 24, 2004 7:28 pm
ok. here's the pinout, i believe. NISTECH's pic was too small, so i dusted my FSM off and looked it up (darn you!)
Next to the fuse box on the passenger side of the engine bay should be three harness connectors. You want the second one (not sure of color as my car is buried in snow right now, but I believe it's brown) The wires you're looking for are Green/White and Green/L (i have no idea what L is, but I always thought it was a plain green wire) Disconnect them from the plug and have a friend stand behind the car as you touch the ends together to complete the circuit. If the wires are the right ones, the backup lamps will come on. Then just run some wire from the reverse sensor (it's the closest to the engine bay on the passenger side of the transmission) to those wires. Polarity doesn't matter in this case cause all you're doing is allowing for a circuit to be completed.
