Backup camera/GPS installed
G35MoonRiver
Car: 07 G35 Coupe, premium package
07 G35 coupe rear view is so limited every backing up makes me very nervous, so I decided to install a backup camera. The whole project maybe helpful to someone, particularly the process of uninstalling the shifter panel.
I am very happy pleased with the result.
Got a GPS with AV in from ebay
and a wireless rear view camera, it comes with a camera, a transmitter and a receiver.
GPS stuck on the cubby lid with 3M Velcro tape.
cubby lid closed, it's becomes invisible, so that it doesn't attract theft.
Here's how I did it.
1) lifted the shifter panel, the hardest part.
First, inserted some pieces of hard transparent plastic such as on toy packing box, around and underneath the panel, note: inserted two pieces in one spot then wedge some small pieces of thick hard paper (again it can be from the packing box) in between plastic, do this along the panel, insert more paper until the panel lifts.
with the panel separated from the black plastic panel, lift the the panel by the ashtray lid and pull downwards to the shifter, it's a big tricky lifting the rear end of the panel helps. See picture above. Now you got it!
2) take off the armrest
then the big panel
unscrewed the screw on the soft narrow long panel on the side the screw is under the shifter panel.
lifted the front end of the big panel
now the rear end of soft long narrow piece can be lifted, as well as middle of it, carefully lift it up, at the same time pull it down, to take it off.
Ran a USB cable from the cigarette lighter socket to out side the cubby
drilled a hole on the side of the cubby to insert the cable in the cubby
there is a hole in the back of the trunk through it the license plate lights wires go out. It's perfect for the camera cable.
fished the cable in
poked a hole large enough on the rubber plug to let the cable go through.
soldered the transmitter hot wire on the backup lights positive wire, it's pink, and ground the transmitter negative wire, I bolted on the amplifier mount.
placed the receiver in the cubby
mounted the camera onto two brackets
Then mounted it on the license plate. It relatively unnoticeable, unless you bend down and look for it.
connected everything together, as soon as shifted into R, it showed the rear view, regardless what the GPS mode is! I installed the Igo Prime on the GPS, now I have a GPS and rear view display in a single unit, it's great!
soul_hfk
Car: 2010 G37xS---08 QX56
nice job :dblthumb:
kmckis1029
Car: 2016 Q50 RS400 AWD
2010 G37x w/Prem, Nav, & Wood (sold)
2005 G35x w/Prem C (traded in)
nice upgrade... you dont even see it on the plate...
joe603
Car: 2014 Durango R/T
Nice mod, and thanks for taking pics! ...would have been a great time to put in an aftermarket head deck, but that would have been more $$.
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
Good job! Nice pics too!!! :dblthumb:
