Backup Camera for 2011 Versa
mikekost
Car: Versa 1.8SL Hatchback, Black on Black, fully loaded
I've just bought a brand-new 2011 Versa 1.8SL, equipped with the factory NAV unit. Does anyone know if this is already equipped to handle a backup camera - i.e. the wiring is already run to the rear of the car, or there is a connection on the NAV unit itsefl.
I've done a search on the forum, and also scoured the handbook, but cannot find anything that sheds light on this topic. Beginning to suspect this means extensive work if I want to add a camera :frown:
AppleBonker
The factory nav doesn't come with the backup camera? Odd. I'm not familiar with the add-on packages for the versa. You may want to try posting this in the Versa section. And check the service manual which you can find here:
http://www.nicoclub.com/FSM/versa/
You certainly should be able to add it, but it if doesnt' currently exist on your ride, I'm guessing you'll have to run the wiring yourself. It's not a terribly difficult job, but it might take an hour or two...
Kompresshun
I've moved this topic to the Versa General Chat forum, that way it'll give some of the Versa owners a chance to chime in and give you an answer as well :dblthumb:
mikekost
Thanks, both of you. I'm brand new to the forum and thought that I had posted it to the Versa section - goes to show I still have a lot to learn!!
Kompresshun
You're welcome! This site is a very large place, so it takes some time to learn where everything is, but if you have any questions feel free to ask and somebody will try to get you a response as quickly as possible :dblthumb:
christian1
Car: 2011 nissan versa sl
I was thinking the same ,I bought 2011V sl Hb with navigation for 15k I don't know if I payed to much for it ,but I was thinking about a back up camera ,and I saw a rear mirror with camera for $40 in ebay or change ,up grade the Gps for one with camera for $360
