I just purchase and Audiovox Camsbar 2, backup camera from Car.toys via Amazon for $150 ( no tax no shipping charge ). An amazing product and easy to install on an '07 Murano S. It includes a 2.5" lcd monitor, backup camera and 2 backup sensors that proximity beep. Installation tips:1. there is a piece of sheet metal held in place with 4 bolts about 5" to the rear of the back bumper. Remove the 2 inner nuts and attach a 5" L bracket to each one. Attach another 2" L bracket to the end that extends under the plastic bumper. Attach the Camsbar to these brackets, centered under the bumper, and as high up as possible (approx. 19" above ground).2. Remove the spare tire to expose the bottom of the luggage area.3. Remove the rubber grommet facing the left side of bumper. Cut an X in the center of the grommet large enough to put the end of the cable coming from the Carsbar through.4. Pull the cable through the grommet.5. Locate the green wire with a white stripe on it ( may have silver hash marks ) that runs parallel to the rear bumper in the spare tire cavity. That is the positive backup light wire. The black wire in the same bundle is the ground.6. Attach the electrical leads provided in the kit to these wires.7. The easiest way to bring the LCD cable to the front of the car is:a. Take the 2 bolts off that hold the left bottom seat cushion so you can flip it up. That exposes the side plastic molding.b. Slightly pull up the moldings so you can tuck the cable into it. You can do this all the way to the Dash.Pop up the left de-fogger vent on the top of the dash and drop the cable attached to the LCD through it.c. Connect it to the cable you just pulled under the dash.8. You are done...Congratulations.
Modified by tkamrin at 10:18 PM 11/23/2009
