Backspacing Range.
The Grand Pooh-Bah
Car: 2001.5 Infiniti QX4
My new shoes arrived yesterday. Cooper Discover A/T's, 245/65R17
My wheels have the blistering issue and am considering new after market wheels.
Is this correct on the OEM Wheels?
17" x 8"
6 Lug x 5.5"
5.29" backspacing
Question:
Can the backspacing be a bit different without rubbing, sticking out too far, looking weird or other issues?
Mike W.
Car: 2003 Infiniti QX4 with a drinking problem. Gone but not forgotten
2002 BMW 525it
2002 BMW 530i/ manual trans
The dark side, 2008 4Runner.. We'll see.
I think the term you're looking for is offset, I'm unfamiliar with backspacing being used with regards to wheels. The wheel specs are 17 x 8JJ Aluminum/20 (0.79) meaning 20MM of offset from the center line towards the outside of the wheel. More offset moves the wheel in towards the body. Kind of counterintuitive, at least to me, but that's how it's measured. Minor differences are generally ok.
FWIW, while kind of a no name brand that sounds like what I've got on mine and I'm more than happy with them. Reasonably quiet and smooth, have gotten me thru deep sand with no issues and with 20K on them they look almost brand new.
The Grand Pooh-Bah
Does 18mm work okay? It seems to be a more prevalent size.
Mike W.
2002 BMW 525it
The Grand Pooh-Bah wrote:
Wed Jun 30, 2021 6:49 pm
I'm not an expert, but 2MM further out is nothing with stock sized tires. I can't imagine it would not work it's so close. The same size tire by different manufacturers will vary by more than that. You're good with 18MM offset.
The Grand Pooh-Bah
I ended up ordering
Ultra Maverick 235
Model#235-7883B
Wheel= 17x8
Bolt Pattern= 6x5.5
Offset= + 10mm
Bore- 106.10mm
$549.24 delivered
Mike W.
2002 BMW 525it
10MM less offset means they will "poke" out 10mm further. But 10MM further out on a 4WD truck is next to nothing so you should be just fine.
