Backfiring under boost
NissanTurboSix
I back fire like CRAZY when I hit boost at more than 1/2 throttle or so. I have NO boost leaks. My IC is air tight.
I have GReddy Profec B II and FMIC. I am getting vac. source from the IC pipe closest to the throttle body.
I think the problem might lie within the setting of my boost controller because when I play with the settings it seems to get worse. The only problem is, I can't seem to get it better.
If you think its Profec B, can you post some settings that should work as a baseline?
If you think its something else, please share! Thanks.
themadscientist
sounds like weak ignition misfiring. See if it goes away when you drop the boost. Check the coils and plugs for health.
NissanTurboSix
Boost is set at 0%. Ill take a look at ignition. Thanks for the reply
