Fenvy »
https://forums.nicoclub.com/fenvy-u13048.html
Mon Oct 18, 2004 7:23 am
after I did my sr20det swap, I was still running stock exhaust... no backfiring and the plugs show that I was running lean. phase2 was concerned and told me to get exhaust asap
after I get my exhaust, it start to backfire, especially when I let go of the throttle, plugs read normal
backfiring usually means your car is running rich (too much fuel, too little air). It could be that your bov vents already read air and cause the ecu to think that there is more air then actually is. If your bov can be recirculated, do so... or you can try to stiffen the spring alittle to see if the problem reduce a little. Don't do it too much though, yesterday I soften my springs by 2 rotation and my car stalled after blow off, that means losing power brake/steering: dangerous!
