Try reading through this, should help you out quite a bit. If not, at least they're interesting pictures.
zerothread?id=251133
If you're not comfortable removing the unit there is another way mentioned in the thread.
I've never personally done it this way, but I've heard a few mention it.
CrypticScorpio wrote:Ghetto way to clean iavc is.
step 1. start carstep 2. while having a friend rev engine, partially remove the 2ND (bigger of the 2 hoses) right beside eachother on your intake(stock - going from engine to airbox)step 3. if you have managed to keep car running while pulling it PARTIALLY OFF then continue if not restartstep 4. spray a **** load of throttle body cleaner in there and reatach hose while keeping engine running.repeat as needed
Modified by 89twoforty at 1:08 AM 9/25/2008
