So recently I changed my valve cover gaskets. In doing so I removed the distributor not knowing anything about ignition timing. After completing the job I reinstalled everything and then could not start the car. The crank was sluggish and no start.
I immediately researched and thought that my ignition timing was just off. I wen ahead and replaced all the spark plugs and wires and since this car is new to me and is a project I went ahead and replaced the ignition coil and upgraded the ignition relay to PRW2 with an adapter that I got from PastPowerParts. I also replaced the Crank Angle Sensor along with the other insides of the distributor (rotor & plate) as well as the cap. I also changed the fuel filter and did an oil change.
After completing all of this I tried to start the car again. This time the car cranked much better. The starter was quick and I thought for sure it was going to start, but no such luck. While cranking I can hear the exhaust sputter a bit and backfire. I'm just not really sure if this means anything.
As a side note I did find that my negative battery wire was not bolted to the car, which makes me believe there was no ground. Could I have fried my ECM???
I took it out of its compartment to inspect it. The Red & green lights come on but when I tried to switch modes the little screw broke so now I can't reset or diagnose anything. (35 years of corrosion I guess)
If anyone has any insight on this I would greatly appreciate the help. Does the backfiring while cranking mean anything? What do you think the issue could be?
