backfire(sound) help...
maik21
Car: 90 Nissan 240SX Coupe 5.0
BuLLeTdrift <-- you has reason. i have to buy an cat an install it. ... yes.. i hear that "pop" when i go of the gas.i had other cuestion about this.. if i put an extra pipe(large(eliminate sound)) will it work>?
BuLLeTdrift
Car: 91 240sx fast baq
it'll prolly just get louder w/ bigger piping. an even louder "pop". becuase you're running a straight pipe. so a cat will most likely get rid of that sound. but its nothing to worry about, unless you really are bothered by it.
navysnail
mine use to do that, my injectors were leaking internaly (3 cracked). replaced them with bosch, now it doesnt happen any more.
maik21
thanks.. i buy a cat and install it. =) thanks
MikeMurphy
Car: Guess
Thats cool. I have a cat too and it still makes the sound.
gyfer
CAT is not going to cure the problem. It will just silence out the pop.
