KingTurd »
https://forums.nicoclub.com/kingturd-u68620.html
Fri Jul 13, 2007 5:59 pm
Greetings all.
I have a relatively annoying problem with my sr20det (s13). After boosting slightly (or moderately), releasing the gas and then pressing the gas again, I usually get a backfire. It really only happens when boost of any kind is made. It will only backfire once I touch the gas. For example, if I make slight boost, release the gas and coast, nothing happens. However, if I make slight boost, release the gas, coast for about 2 - 3 seconds and touch the gas it will backfire, but only the instance I press on the gas.
My blow off valve is not vented to the atmosphere, its recirculated. Its a TurboXS RFL. I am not sure if I have it too tight or too lose. It does open after very slight boost (as well as when im making no boost at all), and opens very well upon higher psi. Im afraid to make it too tight as I might risk surge, yet I sometimes think its too loose. Anyone got any tips on how to tell its just right? The car idles at around 15-16vac and coasts around 20-21. The spring seems to be decently stiff, but I am not an accurate gauge of that As of right now it has one washer installed and the cap is tightened all the way down.
Also, in the same token, the car "seems" to pull timing like crazy. The timing is set to 15* w/ no TPS as per the manual. For example, sometimes the car will feel very sluggish/slow/retarded when boost is being made, and other times it pulls hard. I might have found a source, however. The manual says that the TPS sensor should be adjusted between .35 and .60 volts. Those arent exact numbers (I cant remember what they are at the moment) but I know that its between those two. However, when I was adjusting it, I could only get it as low as .30 and as high as around .47--meaning turned all the way one way and the other. Granted the voltage is within specs, but it just seems odd that the highest voltage I can obtain is .47 volts and not at least .60 volts. Maybe this is the culprit? I had it turned all the way to one side, reaching the .4x volts and drove around like that. It would lag severely after a while of driving it. I havent checked the resistance on the TPS, only voltage under operation. As of right now the tps is basically set in the middle, and it still does the hesitation, but not nearly as frequent.
Maybe the TPS is causing the backfire? It does smell slightly rich. Also, when I bought spark plugs I got them for a '91 ka24de as I had read somewhere that these would work (gapped correctly, of course). The sluggish operation seems to happen with time, almost like after things start to get heated up. Then again, it pulls file other times. Lets face it, intermittent problems blow.
Any ideas? This message seems rather unstructured but I was trying to type the problems as I thought of them.
Thanks in advance!
