Back window tinting
ZMARKUS
Car: 1999 Infiniti Q45T
2002 Infiniti Q45
When I purchased my used Q it already had a tint job, although aging and due for replacement. Well that day is about to come but as with my tint job and other like models, the back window is seldom fully covered with tint. It's the small portion of the upper end of the back window that tends to always be left untinted like mine. What is the reason for this and can it be tinted without consequences?
Ludeaem
Car: 2000 Infiniti Q45 AE
its a Teflon coating that makes the tint not stick to it. Some tinters don't tint that or some go over (like mine) and it looks ok.
ZMARKUS
2002 Infiniti Q45
Ludeaem wrote:its a Teflon coating that makes the tint not stick to it. Some tinters don't tint that or some go over (like mine) and it looks ok.
Whoop there it is.
ZMARKUS
2002 Infiniti Q45
Hey wait a minute. Why the h*%& did Infiniti put a teflon coating there?
NightRiderQ45
Car: 1998 Infiniti Q45
Hmmmm...interesting giving the fact that my tint stuck on the back window.
Ludeaem
its sticks per say it just doens't adhere like the rest of the window. There is a trick of using elmers clear glue to make it stick if it looks bad
NightRiderQ45
Ludeaem wrote:its sticks per say it just doens't adhere like the rest of the window. There is a trick of using elmers clear glue to make it stick if it looks bad
Per say my arse. My tint looks great on the back. I don't know who did your install (especially since you're thinking about using elmers glue), but mine looks great. The upper part of the glass just took longer for the glue to dry because of the small holes that makes up that part of the defrost system.
Ludeaem
take a pic and let me see
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
Most cars have a black ceramic 'frit' edge on the rear window. Sometimes this ceramic edge is straight and flat, sometimes it will have a dotted matrix edge. These black ceramic dots are quite thick on most cars and prevent the film from sticking to the area between the dots. This results in a whitish looking strip trimming the glass.
Typically this isn't very noticeable, however some cars have a wide band of dots trimming the top of the rear window. This area is so wide that the whitish looking area created is more pronounced.
Not much can be done about the narrow strip of dots going around the edges, other than letting the film dry for a few days and then pressing the film down onto the dots with your finger or a hard card wrapped in a paper towel. usually this will greatly reduce the whitish appearance. This usually doesn't work well for the wide band of dots.
There are a few options for dealing with the very wide dot matrix area.
Paint ThemThe dots can be left untinted, the film allowed to dry for a couple of days, then painted. The best way to paint the dots is to use a flat black enamel spray paint. Mask off the tinted area and upholstery trim with plenty of plastic and masking tape. Make sure to get a good straight edge where the paint will meet the tint.
Glue Them ***my favorite way***
Another way is to use a clear stationery glue such as "O' Glue" available at Kinko's or Thrifty's or RightAid or any stationery store or Elmer's blue gel (dries clear and stays pliable) . It is a little tricky and can be messy. It gets a little easier with practice. First tint the window as normal, covering the dots with tint. squeegee as much water as possible from under the dotted area. Carefully peel the film down from the dots and squeeze a bead of O' glue onto the exposed film where it meets the bottom edge of the dot area, lay the film back into position, and carefully, slowly squeegee the glue upwards with a bondo card wrapped in a paper towel, stopping short of the top to keep the glue from glopping out. When all of the glue has been moved to nearly the top, squeegee the rest out with a horizontal pass of the bondo card, holding a paper towel under the squeegee card as you go to catch the excess glue. If you spill the glue on the upholstery, just wipe the excess up, and blot with a wet paper towel. If you smear some onto the surface of the tint, just wipe it away with a paper towel. As the glue dries, it will look lumpy for awhile , if the lumps are huge squeegee a little more out. Most of the area will appear a bit lumpy even after its dry, but it looks MUCH better than having that whitened look from the outside.
More on gluing (pics included) HERE
Source: http://www.tintdude.com/dot-matrix.html
Haitian_King
Did this ever get resolved?
