navysnail »
https://forums.nicoclub.com/navysnail-u13430.html
Sun Nov 07, 2004 3:39 pm
unbolt it from the transmission (assuming you have a manual) then screw the other one in. you will loose a little bit of gear oil, but if your quick about it you will be fine. also, put some thread sealant on the threads of it so it doesnt leak. you can test the sensor on it now with a multi meter, just check the resistance of it with the transmission in and out if reverse, it sohould be 0 or somthing around that when in, and wont flow when out of reverse
