Back up lights are out
GreenQ45a
Car: 2012 Altima 3.5 SR CVT - Dark Slate w\Black Leather Sport\Tech\Premium
2010 Pathfinder 4.0 SE Auto - Red w\Grey Cloth Towing Pkg\Tech 1
I noticed last night that my backup lights are not working.
What are the odds that both bulbs would go @ the same time?
What's the best way to check them out?I checked the fuse box but did not find a Back-up light fuse.Should I check them with a multi-meter? if so what settings would I use?
DAEDALUS
Car: 1990 Infiniti Q45
GreenQ45a wrote:What are the odds that both bulbs would go @ the same time?
A couple years ago I would've said next to nil. I have a best friend (not a car guy) who I discovered was driving around with 4 burnt out brake bulbs. Took me an hour to figure out cause I just assumed it couldn't be the bulbs. How long has it been since you knew they were working?
You can check for continuity of the bulbs (lowest ohm setting). Or check the sockets for voltage in reverse gear. Or just hook up the bulbs to a battery (I assume they're 12v bulbs?).
