Socaldiablo »
https://forums.nicoclub.com/socaldiablo-u163627.html
Mon Aug 29, 2011 12:34 pm
You could try looking at the camera connection to see if it is compromised. My rear glass window release switch has failed twice b/c moisture is getting down in that area. This same area where the switch is located is also where the camera connection is. You have to remove the tailgate panel to gain access to this but we can walk you through it if you want to play around with it. My guess is your problem is somewhere here as opposed to a problem with the wiring to the nav screen where the image is displayed.
