96Qowner wrote:Congratulations, Haitian!
Now you won't have to listen to the old farts carp at you anymore. Good job.
Tell me about your driveshaft - I think mine's going bad. Do you get a shuddering vibration at around 21-26mph? I get it in any gear.
Yes. It comes as a relief, but I may miss the attention.
Driveshaft? Yeah, mine was diagnosed the first time I went to Keith's. He said that it was a common problem with the 90-93 Q's. They were replaced under warranty constantly. All of the old threads I saw here about the G50 driveshaft said that most of the issue was caused by that rubber bearing that was considerably thinner in the 90-93's and was upgraded to a thicker one in 94. I believe Tech said that the OEM shaft was designed for 100k. My Q is at 91.7k miles, so it's almost time. I don't know if Mark (xr4racer) still has his driveshaft from the 92 he was parting out. He was going to let me have it for $100. It had about 10k on it so it should last another 90. I was undecided on whether to go with the slightly used 92 shaft or just get the brand new OEM shaft with the thicker rubber.
superuber wrote:Yes, interested in your driveshaft issue. Are you going oe or aftermarket?
Don't rightly know. I'm leaning more towards OEM. It really depends on the price difference. If the difference in OEM vs Aftermarket is huge (durability factored in as well) then I may go with one or the other. If the price difference is small, I might as well go OEM, just for the peace of mind.
ddrumman wrote:Congratulations. I bet you will do a few WOTs for $hits and giggles just because you can. I'm sure you'll do well with the wheels and suspension, and before you know it you'll have one of the nicest Qs out there.
Enjoy!
I've tried. I'm a little chicken though. I don't really have much open road with which to enjoy my newfound performance. What little open/low traffic roads I do come across, my paranoia kicks into high gear and I'm afraid to go for it for fear of a hidden police cruiser armed with a radar gun.
I'll be less afraid once I get a radar detector though. And new tires. My rears aren't in optimal condition and I'd rather not have them fail at high speed.
