Back to ca18det running bad
LandrethRacing185
Car: 1986 Corolla ae86
Ca18det powered
Had my ca running great went drifting and everything cool
Month went buy nothing changed
Went drifting Saturday made 1 pass then started sputtering and shooting flames
Took plugs out changed them to new bcpr7es-11 .8 gap no change
Found blown hose
Fixed it no change
Changed maf and change from blow threw to inducted
No change
Messed with cas and tps
No change
Let it cool down
Made 1 great pass
Then sputtering again once hot
Came home and found coroded coil pack springs and broke one
Changed it to a neon coil pack with wires
Ran great cold once warmed up sputtering not revving past 4-5k
No ecu codes on the ecu
Anybody had this problem
Thanks
float_6969
Ignition Amplifier
boost_boy
First of all, why are you running such a cold plug? Those 7s will foul-out if you don't have the need for them or the components to enhance energy to them. Check your spark plugs and if you can, replace them with the 6s.
LandrethRacing185
Ca18det powered
Been awhile since i posted but here is what i have done
Replaced ignition amplifyer with one from a newer q45 syle wired in
changed coils to a neon waste spark coil with 8mm wires
still my problem occurs
runs bad spits and back fires wont rev up well
pull plugs and they are black
changed plugs ran for like 5mins took them out and still black
one thing i noticed while i spin the cas with it in my had is that all the injectors seem to fire no matter witch plug is about to fire
checked ecu codes and i get 55
this is starting to irritate me to the point where im thinking bout going sr20
do yall think that my cam angle sensor is wigging out or maybe my drop resistor
Ken@PTUNING
Car: '92 Nissan 240sx KA-T
The engine should be in batch fire at cranking rpm so I'd expect all the injectors to fire when spinning the CAS. You mentioned the engine runs fine when cold but rich when warmed up. Your coolant temp sensor may be bad. Check the resistance of the sensor. If there is a discontinuity, it will run it with extra fuel.
LandrethRacing185
Ca18det powered
It used to run better cold than hot
Then now it is running the same hot or cold
It's a fairly new cts like 2 months ago
Imma put a timming light on it and see if I'm dropping spark or if I have some other issue
