back still rubbing
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
dacarver2005
Car: 03 altima 3.5se
03 3.5se altima 20x8.5 wheels just added with 245 35 tires rubbing in the back cut and rolled the fenders helped a bit but still rubs on certain dips or if i have weight in the rear the front is fine factory struts in the rear kybs were added in the front a yr ago before the wheels were installed do i need to put kybs in the rear will they stiffen the rear and stop the rubbin or do i need to go the way of springs
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
You need to install stiffer springs. They will reduce suspension compression considerably. Otherwise, get the fender roller back out and start pulling until the tires clear the fender. That might not be a bad idea to do it anyways.
Return to “3rd Generation Altima Sedan (2002-2006)”
