Back on the road soon
creophus
Car: 240SX SE & 200SX
Well guys after a few weeks of my S14 being down, I'll have it running again shortly.
I had a problem with the stock radiator when I cracked the endtank where the upper house connects. There seems to be a leak around the waterpump too, so just to be safe, I'm replacing the radiator with a Koyo aluminum, upgrading to a Nismo thermostat and a stock water pump.
I ordered from bnecustoms in california, and they gave me a good price on everything.
Is there anything that I should be watching out for when performing this work myself? Any pitfalls to be aware of?
creophus
Bump...anyone...have any input???
nnkfws333
Car: 2004 Infiniti G35 and a 1989 Nissan 240SX
bleed bleed bleed the system correctly since most people come back asking why am I overheating and 99.9% of the time it's because of a not properly bled system...but Im sure you already knew that.
creophus
Nope, I didn't already know that. What's the proper way to bleed the system??
creophus
Bump.
Anyone know more about bleeding the system?
My supplier doesn't have the radiator, anyone have them in stock?
creophus
I replaced everything this weekend and everything seems to be fine. I replaced the waterpump, thermostat, and radiator.
I went with a copper radiator (metal end tanks) and its a direct factory replacement for the KA.
I'm not getting any white smoke out of the tail pipe, so I hope and pray that everything is just fine.
