placham wrote:Sounds like a wheel bearing, jack up the car and move the wheel left to right and up and down, shouldn't have any play. Guess it could also be a sway bar link, when bad they also lake it feel like something is about to brake. Otherwise go over your suspension part by part and check all the parts, for any kind of unusual feel or behavior.
But if it's the wheel, just think how its attached to car, and go from there, don't over think it. Just simple thoughts, and check parts this way.
I only see it as wheel studs and nuts, wheel bearing, axle/ axle nut, suspension links with all bolts and bushings.
Its just nuts and bolts.
ummmmmm on the s14's the bearing is actually bolted to the knuckle, then the hub is pressed into the bearing, then the axle goes through all and a nut tightens everything together, im going with everyone else and saying its must likely the rim, BUT if it was a big enough it, the strut coulda blown and your wheel is just bouncing on the spring.
