Back in the saddle! Need some advice
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
My story:
Traded my stock 1992 240sx ka24de for a 1990 s13.5 sr20det(busted head)
I got a new head from a member on this forum and replaced the head and chain and gaskets. I made a mistake yesterday with the timing chain and ended up getting my intake cam at the 11'oclock position instead of 10. Turned it over a few times before i realized it wasn't running right.
Today i fixed the intake cam to the 10'oclock position and the exhaust to the 12'oclock position. I then counted the chain links inbetween the cams to 11. Crank was at 0tdc when resetting cam alignment. Btw i did remove the cam caps while performing this task.
I get her fired up today and running but had to advance the cas fully to get it to start. Also did poofs of white smoke coming from the exhaust. I assume it's fuel related.
I do not know the history of the motor except for looking at the maf JWT POP CHARGER MAF and Super T28 garrett turbo stock intake but not sure if stock injectors. Spark plugs set to .032 and check all 4 coil packs for spark and check all 4 injectors by unplugging each one and watching and listening for change of engine tone. Everything is working. I did not see any boost leaks also put in 5 gallons of new fuel today and new plugs and new fuel filter.
any ideas?
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Sounds like your timing is still just a little off... The 12 oclock position on the cams if you're using the indent to check it is more like 12:30 in my experience.
P.S. Do you play on XBox Live as UMSC G3t Som3 ??
EDIT: 1337 (LEET) Post...
USMCgetsome
lol no brother it's usmcgetsome210. I'll redo the timing again next weekend the exhaust cam did look just a lil off. still had the 11 links between the alignment dots
