cellis25 »
https://forums.nicoclub.com/cellis25-u34246.html
Tue Nov 08, 2005 4:32 pm
well look at it this way, anywhere theirs a seam that has to do with rubber its posibly rotted. look at the hatch or the moonroof, easy test get in the car and have a buddy spray from the front with a hose, look to see where its coming from (kinda like your driving down the road with the rain running from the front to the back of the car, then look with a flashlight if nessasary then around windows and door seals. if you try this for a while and dont find anything look under the car see if theirs a rust hole or a old drain plug missing, when driving through water i will soak up into the padding and carpet
