back firing after 4k RPM?
hvp014
Car: 89 R32 GTR
heymy CA has just started acting up... if I stomp the gas, and when the motor hits 4 thousand RPM it starts backfiring real bad. It sort of sounds like its running too rich, and you will lose a considerable amount of power. It will continue to rev however just slowly and it sounds horrible. If I'm easy on the throttle I can get it to rev higher but it does the same thing around 6K.
So far I've replace the plugs, fuel filter and added injector cleaner.
The motor is stock aside from a front mount, apexi cone.what do you guys think I should check next?
lostmenoggin
Car: 1989 Nissan 240sx ca18det swapped
ecu self diagnosis test (mode 3).
mbmbmb23
hvp014 wrote:heymy CA has just started acting up... if I stomp the gas, and when the motor hits 4 thousand RPM it starts backfiring real bad. It sort of sounds like its running too rich, and you will lose a considerable amount of power. It will continue to rev however just slowly and it sounds horrible. If I'm easy on the throttle I can get it to rev higher but it does the same thing around 6K.
I would send the injectors out to be cleaned and flow tested (www.deatschwerks.com or something) then test the fuel pressure regulator.
-m
sydwayz
Car: 1992 nissan 240sx
if its poppin a back firing doesnt that mean its lean and rich is when it boggs down and wont rev 4 **** and is slow as piss??????????????? idk
busteds13
Car: 92 S13 Hatch CA18DET, BOOST!!
double check your fuel pressure, run good gas, check your TPS plug, and pray for cold weather
rico05
Car: 1992 RMS13 w/ CA18DET
Check for vac leaks. I second the fuel pressure issue as well.
Hudsontec
Car: 1989 240SX w/RB20DET, 1991 S13 SE W/SR20DET
Have you checked your MAF?
hvp014
Car: 89 R32 GTR
hey thanks for the replies guys... like I said its a stock motor set up, I'm still running the stock fuel pump. Should I upgrade or will it be allright?
I'll get a gauge this weekend and let you guys know what the pressure is.
Also something maybe unrelated my idle is between 1500-1600. Hybrid dynamics says its because of a bad IACV. I tried adjusting the screw on the side of the IACV but it does nothing. What do you guys think.
