Back and dash lights?
steff
Car: Nissan 240 sx 1989 sr20det
Ok so here is my problem.
I have a 240sx 1989 sr20det and the back and dash lights won't work. I've played with the wires and it didn't work at first so went back to work and when I've started my car.. MIRACLE! it was fine and so my tail and back lights but as soon as I got home.. nothing.. and nothing since then.. My brakes lights are working and I've check the fuses and they're fine.. I'm not a master in electronic so I need your help please
Thanks
s13bassboat
Car: 1993 240sx coupe a.k.a bassboat
Check your ground wires around the fuse box and battery. Thats were i'd start
TKOcrewSR
Car: 1990 nissan 240sx
its most likely your turn signal switch
