float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Wed Jul 31, 2013 8:13 pm
First off, lets talk about the actual problem. Detonation during boost.
When you say detonation, I assume you mean you're hearing knock during boost. This situation is caused by 3 scenarios. First is too much spark advance. You've eliminated this variable by retarding the timing as far as it will go. IIRC, when the CAS is set to full retard, the base timing is actually ATDC. That is enough timing retard, that if the issue was related to spark timing, it would have gone away, so we know it's not timing.
Then there is the air to fuel ratio. The AFR under boost has a direct connection to the amount of spark advance that is needed for any given situation. If it's actually leaning out enough to cause knock, you could tell by monitoring the voltage from the stock narrowband O2 sensor. An engine usually has to be pretty lean (13:1 or leaner) to knock.
Next is a lack of octane for the combustion environment. This can mean A LOT of different things. The first thing to try is to run the boost as low as it will possibly go. If this solves the issue, it's either a lean situation, or the combustion chambers are dirty and are creating hot spots. If this doesn't fix the issue, empty as much gas out as you can. Then go buy 5 gallons of Toluene. You'll have to go to a painting supply store. It's usually used as a paint thinner, but it's a petroleum product like gasoline and has a VERY high octane rating (AKI = 114). If the issue is related to poor gas quality or combustion chamber deposits, this WILL fix it.
I just thought of this... did you see the new pistons? What if they're CA18DE pistons? If so, you now have 10:1 compression and you're trying to run boost on top of it. I can tell you FROM LOTS OF EXPERIENCE, this is almost impossible to do on this motor on 91 octane pump gas. If you don't know about the pistons, I would do a compression test and see what the numbers are like. If it's new DET pistons, compression should be around 175psi. If it's DE pistons, it will probably be closer to (or even over) 200psi.
