Has a code for the bank 1 sensor 1 heated oxygen sensor which I replaced with a sensor from the Nissan dealership.
I am unable to get the bank 1 sensor 1 Sensor to pull up on live data on a scan tool I checked the fuse for the heated oxygen sensors I believe there is only one I could be mistaking, it looked OK. I don't understand what's going on it could be something with the connector itself?
Short term trim on b1 goes from 0%to 25% sporadically. When it does this, I get an OL fault on fuel system 1 for bank 1.
Side note I do have 6 brand new OEM ignition coils I am going to put in to see if it changes anything but I still need to determine why the bank 1 sensor 1 oxygen sensor is not pulling up as a PID on the scan tool under live data
Any help is appreciated
