B16 Video Receiver Install
XaberTheBlade
Car: 2012 JukeSV 6-Speed
I just won a free Pioneer AVH head unit! Double-din dvd, nice little unit. Gonna install it into my 2008 Sentra. Issue is...as many regular decks that I have install, I have never done a video receiver like this. I would really like to do the install proper, which means actually wiring the parking brake lockout correctly NOT DOING A BYPASS. I don't plan on ever playing video while moving and I don't want to dig holes or install a switch just to 'hack' the unit to play. Since I have no clue how I go about wiring into the parking brake (or the reverse signal for that matter), I was hoping someone could either explain where it needs to go or point me to a good resource for this since everything I have found is only a bypass install...which I don't want.
WDRacing
Congrats on the stereo win! Do none of the bypass install articles indicate how the wiring should be prior to the bypass? Meaning can you not work backwards?
XaberTheBlade
Unfortunatly no. I have looked all over youtube, and the nets. seen tutorials for the unit, the car, the unit and the car, but every one of them is apparently a homebrew hero and all of them do a bypass. The best solution I have found thus far is to actually wire it into the Illumination line. That way I can just turn my lights on and off and it will trip the ground same as a bypass without needing an extra switch. This is still less than ideal. As much as I would hate to pay for it (between my own pride and skills), I may need a pro to do it unless I can find the right resource :/
XaberTheBlade
Welp, I figured it out. It looks like there is a bypass adapter you can install behind the head unit that hooks right in with the existing wiring harness. It is basically a relay. It triggers the ground that the safety looks for and then holds it. I still don't plan on watching while I'm driving but I am glad there was a simple solution that didn't require some half-a** hack and a random hole and switch somewhere in my console. You can get them from most audio shops or amazon. Problem handled :)
