bubdad1 »
https://forums.nicoclub.com/bubdad1-u311858.html
Mon Sep 09, 2024 5:56 pm
@VStar650CL,
Thanks for the tip. Turns out I have a bad front subframe bushing. When I lowered it as you suggested, there was nothing left. So... I removed the subframe.
I now have an issue where I can't remove the pull down rod (item 12 in the EM section of the 2011 repair manual from this site). The bolts holding the rod in place feed through two bushing in it. I have a heavy duty impact wrench and it spins the bolt slightly then stops. To drop the subframe, I had to cut the rod in half using an angle grinder.
My guess is the bolts have frozen in the bushings due to rust. I've used penetrant and striking it. No luck yet but the bolt moved a bit more today after an overnight soak of penetrant.
Any ideas on how to get these bolts out? There is no way the bolt came out like it did on a YouTube video I watched. LOL
Also cleaning off the metal centers of the old subframe bushings in preparation to use new Polyurethane ones I purchased from PSB. Will burning the rubber off change the diameter of the metal? I was able to use a wire brush to clean the bearing holes on the subframe so I'm set...
As always, I appreciate your help and this forum.
