BOLricoNY »
https://forums.nicoclub.com/bolricony-u103980.html
Sat Nov 21, 2009 9:28 pm
(I DID NOT RIGHT THIS UP[created by AZNHAVOK at myspec-v.com]). Ive been searching around for a way to change the way b16s fog light are setup. from factory you need to have your low beam to get your fog lights to turn on, I wanted to have it turn on with my park lights. after my search ive came across a way to accomplish this from the site/forum nicoclub
here it is.note i did not write it up but performed the mod to my b16 with no problems
In this article we will show you how to bypass your fog lights so they come on with your parking lights using the factory switch.
Skill Level 3 of 5
Time Required <1Hr
Tools and Supplies
-Wire strippers
-Mini fuses
-Add-a-circuit, or similar device
first go to auto zone, advanced auto, pep boys, what ever you have localy and find an add-a-circuit(also called a fuse tap. looks like this Parts Express but you need one for the MINI fuses)
1:Remove your under hood fuse panel lid and locate the tail light fuse.
Note:If you want the lights to be able to come on without any other lights you will need to find a different fuse to replace.
2:Remove the fuse and put aside.
3:Now cut the connector off the end of the fuse tap as close to the connector as you can. you will need a blade connector and strip a small amount of wire to hook the blade connector up.
Note:You will probably need to grind down the connector some unless you have some very small blade connectors. this can be done with a bench grinder and a pair of needle nose pliers. use a fuse for a guide.
4:Crimp the connector on the fuse tap and install the tail light fuse in the tap(follow the instructions that came with it).
5:At this time locate the fog light fuse and remove. install that fuse in the empty slot on the fuse tap.
6:Now install the tap in the tail light fuses spot and connect the blade connector in the "cold" side of the fog light fuse slot. it was the lower of the two.your fog lights will now come on with the parking lights as well as with the head lights. GOOD LUCK GUYS AND GALS!!
Modified by BOLricoNY at 11:56 PM 11/21/2009
Modified by BOLricoNY at 11:58 PM 11/21/2009
