B15 Sentra -P0171 & P0174
Forkster
This keeps coming on my Sentra - I clear them, the come back a little while later. MAF dirty? Anyone else have this exact same issue? The codes say "System Too Lean"
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Those codes together usually mean a vacuum leak, although they can also be caused by a bad MAF, a front HO2S that's dying but not dead, or bad fuel. The most likely cause on an older Sentra is an intake boot that has hardened and developed a small split.
Forkster
Thanks VStar - I'll take a look on those. For the MAF, is there a way I can test to see if it's still working with a multimeter?
VStar650CL
Technical Expert
Forkster wrote:
Wed Feb 24, 2021 11:42 am
No, it's a PWM signal and the ECM calibrates to it, a VOM won't tell you much. But even most cheap OBD scanners will stream it.
Forkster
Some of my troubleshooting. Voltages seem OK for the O2 sensors - fluctuating between 0.1 and 0.9 V. Mass airflow sensor isn’t jumping around everywhere, when compared to the throttle position moves up nicely.
I have a question (pic 2), this hose I have circled in red, is that supposed to be connected to something or is it just an exhaust hose? It is connected to the airbox.
Pic 1
Pic 2
Pic 2
VStar650CL
Technical Expert
Forkster wrote:
Sat Mar 06, 2021 2:08 pm
It's the CVT vent hose. No, it doesn't connect to anything.
Forkster
Thanks Vstar. Ok, I used to ole WD-40 spray&pray to find the vacuum leak - no joy. If I was to connect a smoke machine, what hose can I connect to in the engine (if it’s a vacuum issue).
VStar650CL
Technical Expert
Forkster wrote:
Sat Mar 06, 2021 2:51 pm
There's an evap service port, but basically anything into the plenum that's un-ported. The booster is convenient, but if there's no joy make sure to smoke the booster itself and check inside the car, diaphragms can leak.
Forkster
VStar650CL wrote:
Sat Mar 06, 2021 2:58 pm
Good point - My smoke machine consists of a nice long transparent tube, and a Montecristo #4. :D
Forkster
Ok - smoke test shows no vacuum leaks. Onto next items - MAF sensor?
