If anyone can answer the following for me (nico search has always blown):
b15 and b16 engine block differences (courtesynissan images certainly seem different (even starter position may be different). I've also heard the sleeves are a little thicker in the b16.
Head differences?
B15 w/b16 crank and rods feasible w/o modification? ecu issues?
b15 & b16 engine mounts or mount position identical?
b15 & b16 Transmission bolt pattern same?
b15 & b16 ecu conflicts in btwn? say b16 engine into b15 w/b15 transmission.
transmission spline to engine same?
Mechanical throttle body for either engine w/o much effort required?
b15 & b16 engine heights?
Thanks in advance.
