Post by petey_97 » https://forums.nicoclub.com/petey-97-u106158.html Wed Oct 05, 2011 3:09 pm
Post by Tim Rogers » https://forums.nicoclub.com/tim-rogers-u189155.html Sat Oct 08, 2011 4:40 am
Post by King Ranzo » https://forums.nicoclub.com/king-ranzo-u72205.html Fri Oct 21, 2011 7:12 am
The 95 is OBDI, not OBDII. They sell conversion harnesses so you could probably find it somewhere on a forum.Tim Rogers wrote:It should work...
Same engine, same chassis, both are OBDII.
If you can't see anything physically different between the two engines, then the wiring harness and ECU should be the same.
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
