B13 supension help?
nismo1003
Car: Ka24de
I got a 97 Altima, the only available strut for us is only Tokico Blue with is the wrost supension they available for us, I am looking into some Custom supension such as Koni insert or KYB AGX Cartridges. I did some reseach , I found out that the B13 Sentra strut is similar to the altima so is the NX, could anyone veify that or has anyone done that swap before? let me know what you got, would you give me the part number on those Koni that u guys using on ur B13?
p.s. if you could .. would you mesaure the space between those two bolt at the bottom of the strut? and the totaly lenght of the strut ( with the rod) Front and Rear.I live in Dallas Tx area, if anyone had a set of stock supension that I can compare with would be help alot.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
The altima suspension is not similar to the B13 suspension. Although it is similar to the P10-P11, which is a Infiniti G20. So don't know if would be an upgrade or not.
