Front or rear Koni struts for B13 chassis built to your Specs. Lower your Sentra and still have suspension travel. Complete bolt in assembly comes with Ground Control adjusters and your choice of Eibach ERS spring rates. The piston rod is designed to fit through a 5/8" bearing/camber plate. Single adjustable Koni 8610 ($1000 per pair) or double adjustable 8611 ($1200 per pair).
