I doubt that B&M made two different shafts for 240sx. I have a brand new Nismo transmission mount installed recently. Do you think it's possible that your transmission mount is worn out, so it's holding the transmission lower than mine or something? idk...Clawhammer wrote:That's weird, my B&M is only as high as your modified one. It's not tall at all, I can wrap my hand around my Grex shift know and the bottom of my arm can touch the boot and bezel. Odd.
That looks short. How was your stock shifter? Was it way longer or just about same height as B&M? Here's the deal. When I tried to remove 2 front bolts on stock shifter, I had to undo the trnsmission cross member and drop it a little to have some more room. How about you?Clawhammer wrote:Just snapped you a pic of my unmodified B&M, Grex shift knob, and Redline boot.
I checked stock shifter this morning, and oh, boy, that thing's THICK!! I think you can still cut it and weld it just like I did if you have a right tool. I had similar problem with shifting after 5-speed swap. 1st and 2nd gear wouldn't go in easily. I adjusted 30631 and it fixed it. My pedal needed like 2-3mm more travel forward. You should try it.punkrocker7788 wrote:Would there be a way of maybe cutting the stock shifter down so its not 4' tall! That would be WONDERFUL!
I switched them back and forth and compared. You can definitely tell there's a huge difference. Stock shifter feels so loose.Hijacker wrote:I never understood the fascination of short shifters. I've used them before and I shift just as quickly with a stock shifter.
Actually, I put new bushings on both. I took both of them apart and looks like this ball joint mechanism is better on B&M shifter and that's one of the reasons why B&M shifter feels better.Hijacker wrote:That's probably due to old bushings
I take it you have never seen the exterior of his car....*drools*AZ89two4Tsx wrote:Your interior is rediculously clean.
Thanks, guys. I've been trying my best to keep it in best condition inside and outside.S13xCrazy wrote:I take it you have never seen the exterior of his car....*drools*.
Not by much. I've tried numerous times, but I've never missed a single gear. It goes in just perfect and smooth. I really like how it feels now.Nacho_240 wrote:How much harder is it to shift compared to the original B&M height?
I have no idea about that 1 long skinny spring. I don't have it on mine. I think it's going to be hard to find same hex bolt, but 3 bolts should be enough to hold the cover down. You should ask B&M and see you can buy any missing parts. Their phone number is (818) 882-6422, and ask for Drew. He's in charge of any problems with short shifter.Nacho_240 wrote:I have 2 stubby springs, 1 long skinny spring, 2 odd shaped clips, 2 black things (they look like mini hockey pucks), 3 hex bolts (need one more), and of course the black cover, shifter shaft and the base. PLEASE HELP ME MAN!
I called B&M tech support, but they weren't able to tell me the assembly procedure. I think he said they were assembled off-site and they weren't allowed to take them apart. I'll definitely give them a call if I can't find the correct hex bolt.94_240sx wrote:Not by much. I've tried numerous times, but I've never missed a single gear. It goes in just perfect and smooth. I really like how it feels now.
This is how it looks. If you add a couple of small washers on top of that hockey puck thing, shifter will be even more solid. I know someone who fixed rattle from eBay B&M knock off shifter by adding washers there. I added to my B&M and it didn't feel good. Let me know if you have any questions.
P.S.: Make sure to use some grease.
Modified by 94_240sx at 6:33 AM 8/22/2008
You don't have to use it for sure.Nacho_240 wrote:regarding the long spring, someone told me it goes in underneath the shifter unit but I don't see the purpose.
Not a problem. You can still install it without one hex bolt, so just go ahead install the shifter and add the bolt later once you find it. Or... it doesn't have to be exact same bolt, so you can get any bolt with same thread and pitch from hardware store. There's some space between black cover and rubber boot as you can see.Nacho_240 wrote:That pic is exactly what I needed! Thanks a bunch 94_240sx
Trust me. I usually have bad luck when it comes to my car, so I bet only mine is screwed up somehow.KA_Pig wrote:Holy sh*t that was a long shifter before you modified it. I have a B&M as well and it was NEVER that long. Its position is exactly where clawhammer's is.
Lol what do you have, KA or SR ? If you have a KA with non-stock mounts, the engine will raise. Why ? I dunno. I test fitted my Greddy before I put on my Kazama mounts and after I put the mounts on, the STB touched the top of my valve cover.94_240sx wrote:
Some good example are...Circuit Sports hood dampers don't fit on mine. Seems like they work great on other s13s. Got the Nismo engine mounts and front strut tower bar won't fit.
