b&m short shifter
erollinc
just went to thier website, and noticed there wasnt a short shifter for the ka24de , only the sr20det....... will the sr SS work on the ka24de transmission?:confused:
Holisticbeatz
It'll work.
red240ne
Car: mmm...donuts
yea, it'll work. go to enjukuracing.com or phase2 or any major 240sx store to buy a B&M.
MarkEmark
Car: fully-built '95 240sx KA-T
Enjuku I think still has deals on them...be prepared to listen to quite a bit of vibration from the unit, especially at around 6000 rpm in second....The performance makes it well worth it, however
scotty-2-forty
Car: 1996 Nissan 240SX SE KA24DET
B&M apparently has a revised edition which eliminates the noise. I will be calling them tomorrow to see if they are doing some sort of retro or buy/trade back on the 1st gens. I'm very pleased with the performance of the unit, but the noise gets irritating. I'll let everyone know tomorrow.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
I have the revised one...and while it's MUCH better than the 1st gen ones I've heard, It's still noisy on the highway at 3300rpm.
I pulled the shift knob and it basically goes away, but there's still a slight buzzzzzzzzzzzzz...
My knob is a solid GREX, so it's not a loose part there...
Later - Brian
TurboKA37
hmmm..... do u think there is anyway of fixing this buzzing noise?
:: orion ::
Hehehehe...NO.
If B&M didn't do it when it first came out, and didn't accomplish it when they 'revised' it...I doubt you and I will figure out a solution.
It's really not bad UNLESS you're on a long trip and at cruising speed...under power it doesn't do it, and upon deceleration my exhaust is too loud, so I dunno...but while cruising, there's a slight buzz.
Later - Brian
scotty-2-forty
I called B&M today, spoke with JP. He said they are trading the old for the new. Call them for an RMA #, then remove your 1st gen B&M shifter and mail it to them. According to JP, B&M will then ship you a new "revised" unit. That's good customer service :) I'll be sending mine tomorrow. I'll give you an idea what I went through to assist in noise dampning on my 1st gen:
1) Taped lead around the counter weight neck.
2) Didn't use the supplied aluminum knob shifter ... that amplifies the noise.
3) Dipped the top half of the shifter in a liquified rubber solution.
4) Pressed small amounts of cork and Dynomat into the shift knob before installing on stem.
5) Made a cork gasket between the shifter plate and base, as well as inbetween the base and transmission.
Hehe, while some of that worked, it sure didn't make too much of a difference ... consider it an experiment ;) The problem is that I really love the shifter! So I gave up and put up with the noise and high-rev vibration. BTW, B&M's fix is not just one to the 2nd gen shifter; they made 5 changes to accomodate the noise and feedback.
cnichols
Car: 96 Nissan 240SX
99 Infiniti Q45
93 Ford Fastiva
I've got a brand new one for sale....$200 shipped.
[email protected]
or
AIM...midcnichols
Sorry, couldn't resist.
tony/ka24de
I have a b&m shoft shifter, I never had a buzzing noise. But I'm going to sell the shifter because I like the way the factory one better. The b&m shifter is really good to, very short shifts and very percise.
