Nismo1182 »
https://forums.nicoclub.com/nismo1182-u2371.html
Sat Jan 10, 2004 6:47 am
I had the same problem with that part popping out. I cut that white ring in half so that its thinner. Put the shifter in with the white ring, put the main C ring on. I took the yellowish ring from the stock shifter ( I had to cut a notch in it to get it out)and put it on the OBX so that it touches the main C ring. Then you can put the little cover and tighten it down.
Now if the shifter tried pops out, it wont pop out like it did to me the first time I installed it. It stays in like normal.
