Hurrikane »
https://forums.nicoclub.com/hurrikane-u3594.html
Mon Nov 03, 2003 6:09 pm
i was looking at some older post on the b&m short shifter making noise.this noise is coming from the springs and flat plate steel inside of the tower.if you remove the 4 allen heads.you will find 2 springs.one on each side,and under the springs the steel plates.i replace the steel with aluminum and smaller springs.this cut down on the noise and gave it a lighter feel. got the parts at lowes superstore in the nuts and bolts dept. you no all the big boxes with all the od parts. if you need more info let me know. hay i got bord on sunday.:ylsuper
