Wulfgang »
https://forums.nicoclub.com/wulfgang-u10889.html
Thu Apr 14, 2005 4:49 pm
As the title says, I installed a B&M shifter on my RB20DET. Also, as some of you may know from trying, B&M does not make a shifter that fits the RB20DET transmission. The shifter they sell for the SR20, P/N 45088, also fits the RB20 NON-TURBO. But it will not fit the RB20DET (I tried). The problem is that the striker arm in the SR20DET/RB20 is about 15mm longer than the RB20DET striker arm. Thus, the shifter runs out of range because it has to reach too far forward to fit into the RB20DET striker arm hole (don't worry, the pics will show what I mean).
However, there is a way to get a near-perfect fit using the KA24 striker arm. By near-perfect, I mean that I got it to within 3 mm of the intended fit (i.e. the SR20DET/RB20 fit). That is close enough to make it shift perfectly and it has a good angle. So here goes:
Step 1: First you need to buy some parts from some NICO sponsors:
a) KA24 striker arm parts from Midway Nissan striker arm - 32844-V5002 $30.47 pin - 32917-E9620 $ 1.15
b) B&M shifter from Injected Performance P/N: 45088 $179 shipped
c) Permatex silicone
Step 2: Remove the stock shifter and cover. You will see the striker arm:
If you measure, you'll see that the KA striker is about 12 mm longer than the RB striker (measuring from the pin to the shifter hole). Ideally this would be 15 mm, but 12 mm works out ok. Here are the two striker arms:
Step 3: The B&M bolt pattern is slightly different than the RB shifter plate pattern. You'll need to drill a new hole (1/2") and fill the one it replaces with something like JB Weld:
Step 4: Because the new striker arm is not quite 15 mm longer, the B&M top plate will have to be beveled slightly to clear 2nd, 4th, and reverse:
Step 5: At some point you'll have to replace the RB striker arm with the KA striker arm. This is difficult with the transmission in the car and easy with the transmission out of the car. Either way it can be done. Choose your poison. Hammer the old pin out, pull out the RB striker arm, fit the new arm on the shaft, and hammer the new pin in.
Step 6: Install the B&M shifter as per the B&M supplied instructions. Use the Permatex to make a new gasket. Don't bother buying a new Nissan gasket... the KA one will not fit and the paper ones don't work that well anyway. Here is the B&M shifter installed and in the neutral position:
This install is really nice if you used the RB x-member because it brings your shifter center right back to within 3 mm of the KA shifter position -- it's almost dead-center again. Plus, now you have a B&M shifter.
Modified by Wulfgang at 2:32 AM 5/3/2005
