its leaking because of the gap between the threads, its leaking coolent. on mine i havent been able to get the motor finished because of same issue you are having on trying to remove that part and line it with thread lockOM3GA wrote:True, Ill probably just leave it alone and finish everything else and see what happens when its running lol. I just dont want any problems. Does anyone know if it is for coolant or oil?
Yeah, mine is leaking from the bottom of that bolt and that was with new water pump and sealent. It leak slow when motor off but when on its drip drip drip fast and yeah once water pump and pully are on you cant get to it.OM3GA wrote:Damn yeah that makes sense, So it is definitely a coolant plug? That sucks i cant find any information on what its supposed to be torqued to, and im assuming it needs to be changed before the water pump? Hmm Its rather frustrating.
Yes, sure. I check 4 times even with water pump off and coolent below pump would still come out of that boltOM3GA wrote:You are 100% sure yours is leaking from that spot and not some part of the water pump dripping on to it? This is gonna suck lol
i dunt know i pull water pump off again, cleaning surfaces cleaning around this bolt and attempt to re seal the water pump. coolent came out from removing water pump but not at the bolt which is lower. i hate to think it was a soft seal at the water pump an finally cure but who knows well seeOM3GA wrote:What the hell are we supposed to do about this? im getting VERY upset lol
THANK YOU!!garagelu wrote:quit b****in and be a man about it. Breaking that bolt loose won't damage the block. The most it will do it strip the allen key. If that happens, drill a hole and use an extractor.
