AZ-Zbum
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
SHIFT_Z
Car: On 4's
2019 Subaru WRX 6MT
Former:
2014 Chevrolet Cruze 1LT
2006 Nissan Altima SE-R 6MT
1988 Nissan 300ZX 2+2
1985 Nissan 300ZX Turbo
1986 Nissan 300ZX Slicktop
On 2's
2018 Kawasaki Ninja 400 ABS
Got a question for you-Looking into getting a new computer for my 85T sometime in the future:
From what you have heard, are the benefits of the JWT ECU worth the $600?Or would you go with the MSD computer they offer for $500?
Also "Buy a different ECU. The stock ECU limits the RPMs to 6500. A JWT ECU moves the limit to 7000 RPMs." from your website...The VG motor's redline is at 6k- With the computer, would that number stay the same or would you be able to rev higer without damaging the motor with the new ECU?
Thanks in advance.-Kev
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
Depends on what your final goals are. The drop in JWT replacement ECU doesn't offer much of a benefit over the stock ECU. It doesn't do more than a couple HP difference at stock boost. However, it does allow you to run up to 14.5 psi while the stock ECU won't handle more than 12.5 psi.
JWT did extensive testing with the VG30 back in the day and decided Nissan was a little conservative in their redline (rightfully so). They feel the motor will rev to 7000 rpms with little to no damage.
SHIFT_Z
Car: On 4's
2019 Subaru WRX 6MT
Former:
On 2's
Awesome thanks for the info.
What do you shift at when you're running yours hard?
AZ-ZBum
SHIFT_Z wrote:Awesome thanks for the info.
When drag racing, about 6500.
Even with my NA, I've bounced the rev limiter a couple times.
SHIFT_Z
Car: On 4's
2019 Subaru WRX 6MT
Former:
On 2's
1 last thing- In your walkthrough to modify the center-pod gagues, did you use the stock boost line for your aftermarket boost gague or did you run a new one and tap it somewhere?
Thanks!-Kevin
Edit: I looked around online, looks like the stock boost is ran on electricity, so thats not going to work. I still am not sure where to tap the line into, and since I have a vac / boost gague, I don't know where to run the lines. Is there a writeup somewhere for this or am I on my own?
Modified by SHIFT_Z at 12:38 AM 7/20/2005
AZ-ZBum
Anywhere you can find a space for it. I chose the stock location. It's on the passenger side of the plenum. I'll try to remember to take a picture tonight and post. The most difficult part was routing the hose into the cabin without kinking or cutting it. But both my boost gauge and turbo timer run off the same source. The boost controller is on a different hole in the plenum.
Heh. How do you like that? I do have the pictures online already.http://www.netsnapshot.com/pcw...=1977
Pictures are at the bottom.
SHIFT_Z
Car: On 4's
2019 Subaru WRX 6MT
Former:
On 2's
OK more problems, starting to go nuts
With the Autometer gague, I only recieved 1 adapter / ferrule / sealing nut (all of which are needed to attach the boost line to the back of the gauge...For me to tap into the manifold location you specidied, I would need another adapter / ferrule / sealing nut- Can I get these items from a hardware store or do I need to order them separetely? I got all of the hardare I am supposed to have, because since I have a vac AND boost gauge, I am supposed to tap a vacuum line and use the T-adapter, assumingly.
In the end, are there any vacuum lines that I can use the T adapter so I don't have to go get more hardware?If there is no easy way to do so, where do I get the extra needed materials to use the manifold location?
Thanks again for all your help,-Kev
AZ-ZBum
Everything I have was done with parts from the plumbing aisle at Home Depot.
Return to “Datsun Z Forum”
